*lineextendtoline
Extends line1 to line2.
*lineextendtoline line1 line2 capture_radius derivative direction
HyperMesh Tcl Modify Command
- line1
- The ID of the line to extend.
- line2
- The ID of the line to which line1 is extended.
- capture_radius
- If the point at the end of the extension is within the capture_radius of line2, then force the end point to be on line2.
- derivative
- 1 - Extend the tangent to the line
- direction
- 1 - Extend the end of the line
None.
