*xyplotcurvemodify
Modifies a curve.
*xyplotcurvemodify curve_name item_name string value plot
HyperMesh Tcl Modify Command
Modifies a curve.
curve_name
The name of the curve being modified.
item_name
The name of the item of data being modified.
string
The string value of the item.
value
The value of the item.
plot
A logical which determines if the current xy plot should be replotted when the change is made to the curve.
None.
