*swapcontactmainsecondary
Swaps the main and secondary entities of groups.
*swapcontactmainsecondary mark_id
HyperMesh Tcl Modify Command
- In OptiStruct, if secondary is a set of nodes, on swapping it is converted to set of elements.
- mark_id
- The ID of the mark containing the groups to update. Valid values are 1 and 2.
Swap main and secondary entities of groups with IDs 1 and 2:
*createmark groups 1 1 2
*swapcontactmainsecondary 1
# Handle error
}Version History
14.0.130
