*intersectmark2
Creates nodes/lines by intersecting 1D/2D elements with a plane.
*intersectmark2 entity_type mark_id plane_id combine_flag break_angle smooth_flag comp_mode
HyperMesh Tcl Modify Command
Creates nodes/lines by intersecting 1D/2D elements with a plane. For 1D elements, nodes are created at each intersection location. For 2D elements, a series of line segments are created at the specified plane that matches the profile of the selected elements that span that plane. These segments are then joined together according to the values selected for combine_flag, break_angle and smooth.
- entity_type
- The type of entities to intersect. Valid values are elems and comps (only elems in comps are considered).
- mark_id
- The ID of the mark containing the entities to intersect. Valid values are 1 and 2.
- plane_id
- The ID of the plane to use for the cut. This is defined using the *createplane command.
- combine_flag
- 0 - Do not combine generated lines.
- break_angle
- The break angle used when combining lines. Ignored if combine_flag is 0.
- smooth_flag
- 0 - Do not smooth combined lines.
- comp_mode
- Parameter specifying how lines are organized into components:
*createmark elems 1 displayed
*createplane 1 0 0 1 0 10 0
*intersectmark2 elems 1 1 0 0 0 1Errors
# Handle error
}Version History
13.0
