*xyplotmodify
Modifies an xy plot.
*xyplotmodify plot_name item_name string value plot
HyperMesh Tcl Modify Command
- plot_name
- The name of the plot to be modified.
- item_name
- The name of the data item associated with the xy plot which should be modified.
- string
- The string value of the data item.
- value
- The value of the data item.
- plot
- A logical which determines if the xy plot should be redrawn after modification.
None.
