*blocknodeupdate
Updates the finite difference nodes in a finite difference block.
*blocknodeupdate name function type start end number factor
HyperMesh Tcl Modify Command
- name
- The name of the block.
- function
- 0 - add nodes to an index.
- type
- The index. Not used, if function is 2.
- start
- The starting position of the nodes to be added or removed. Not used, if function is 2.
- end
- The ending position of the nodes to be added or removed. Not used, if function is 2.
- number
- The number of nodes to add. Not used, if function is 1 or 2.
- factor
- The expansion factor. Not used, if function is 1 or 2.
Examples
*blocknodeupdate block1 0 2 -10.0 110.0 50 1.0
