*morphhypermorph
Create shapes with xyz perturbations for handles on mark.
*morphhypermorph typehand markhand xi yi zi xx yy zz sys sym con
HyperMesh Tcl Modify Command
- typehand
- Handles
- markhand
- Handle mark number
- xi
- 0 - Do not create x perturbation
- yi
- 0 - Do not create y perturbation
- zi
- 0 - Do not create z perturbation
- xx
- x perturbation magnitude
- yy
- y perturbation magnitude
- zz
- z perturbation magnitude
- sys
- System to create perturbations in (default = global)
- sym
- 0 - Do not use symmetry
- con
- 0 - Do not use constraints
*morphhypermorph HANDLES 1 0 0 1 1.0 1.0 5.0 3 1 1
A shape is created for each handle on the mark for each specified direction at the given magnitudes for the specified system. If symmetry is used, all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
None.
