*criteria_write
Writes the global mesh criteria to a file.
*criteria_write filename
HyperMesh Tcl Modify Command
- filename
- The name and path of the file.
Examples
*criteria_write "C:/temp/5mm.crit"Errors
# Handle error
}Version History
2021
