*adjustnodes
Fixes the penetrations by moving only the failed nodes.
*adjustnodes mark reduction scale segment magnitude_mode
HyperMesh Tcl Modify Command
mark
The mark of the entity to be modified.
reduction
The average thickness reduction.
scale
The thickness scale factor.
segment
The segment orientation option.
magnitude_mode
Determines if a magnitude percentage or a uniform size is to be used.
  • 1 - Magnitude percentage.
  • 0 - Uniform size.
Examples
To move the failed nodes. *createmark() and *templatefileset() are required.
*createmark groups 1 "E2E"
*adjustnodes 1 0 1 1 1
