*linesplitatline
Splits a group of lines at a line.
*linesplitatline mark cut line
HyperMesh Tcl Modify Command
- mark
- The ID of the mark which contains the lines to be cut.
- cut line
- The line to which the selected lines should be cut.
To cut lines 14, 15, and 16 to line 12:
*createmark lines 1 14 15 16
*linesplitatline 1 12
*createmark() is required.
None.
