*readnodepositionsfromh3dfile
Modes nodes in the current model to positions given in an H3D file.
*readnodepositionsfromh3dfile path ?animation_number? ?create_initial_xref_cards? ?comps_mark?
HyperMesh Tcl Modify Command
A valid Radioss model must be loaded.
- path
- The full path and file name of the H3D file.
- animation_number
- The animation frame used to load the positions. Default is 0 which corresponds to the last frame.
- create_initial_xref_cards
- The flag to create /XREF cards.
- comps_mark
- The ID of the mark containing the components for creating the reference geometry. Valid values are 1 and 2. For LS-DYNA models, this option is mandatory.
*readnodepositionsfromh3dfile "C:/Users/default/result.h3d"Errors
# Handle error
}Version History
2017.1
2021 - Added optional arguments animation_number and create_initial_xref_cards.
2021.2 - Added an optional argument comps_mark.
