*createfillet
Creates a fillet between two lines.
*createfillet line1_id line2_id radius trim quadselected
HyperMesh Tcl Modify Command
- line1_id
- The ID of the first line to which the fillet line is to be created.
- line2_id
- The ID of the second line to which the fillet line is to be created.
- radius
- The radius of the fillet.
- trim
- 0 - To leave the lines intact.
- quadselected
- The quadrant to select, if more than one possible fillet location exists.
Examples
*createfillet 1 2 5.4 0 0 If more than one possible fillet line exists, you must select the fillet quadrant. The number of this quadrant is then used in the quadselected argument.
