*edgerestore
Unsuppress the selected edge.
*edgerestore edge
HyperMesh Tcl Modify Command
- edge
- The edge to unsuppress.
*edgerestroe 5 Only face edges that are interior to a surface or shared between two surfaces may be suppressed and unsuppressed. Unsuppressing an edge can split a surface into two new surfaces, and causes it to affect the mesh.
