*shelloffset
Offsets shells along their element normal direction.
*shelloffset mark_id corner_type distance_type distance offset_type
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the shell elements to be offset. Valid values are 1 and 2.
- corner_type
- 0 - Offset the elements using square corners.
- distance_type
- 0 - Offset elements using distance parameter.
- distance
- The distance to move the elements. Only valid when distance_type=0.
- offset_type
- 0 - Offset the elements in the positive normal direction.
*createmark elements 1 displayed
*shelloffset 1 0 0 0.2 0*createmark elements 1 displayed
*createmark surfaces 2 1 2
*shelloffset 1 8 0 0.2 0Errors
# Handle error
