*elementconfigcolor
Sets the color for element config.
*elementconfigcolor config color
HyperMesh Tcl Modify Command
The command sets the color for element config.
- config
- The element config that is to have its color changed. This input can be specified as config number or config string label.
- color
- The color that needs to be set for the config specified. This input must be specified as color number.
Examples
*elementconfigcolor 103 2*elementconfigcolor tria3 2*elementconfigcolor 0 0After the color has been set, all elements of the corresponding configuration are set to the value of color.
# Handle error
}Version History
2022.3 - Added support for string labels as input arguments.
