*morphmanualrestore
Restores the positions of nodes after a *morphmanualinit command.
*morphmanualrestore
HyperMesh Tcl Modify Command
To manually move nodes and apply them to the mesh as if they were handles using internally generated domains with inferred edges, then reject the changes:
*morphmanualinit
<<any commands which move nodes>>
*createmark nodes 1 21 22 23
*createmark elems 1 "all"
*morphmanualapplyenvelope elems 1 nodes 1 1 1.0 1.0 2 0.0 0
*morphmanualrestore
None.
