*surfacemarkclipwithline
Splits a group of surfaces with a line by projecting that line perpendicularly onto the surfaces.
*surfacemarkclipwithline mark line
HyperMesh Tcl Modify Command
mark
The mark ID containing the surfaces.
line
The ID of the line used to split the surfaces.
To split surfaces ID 171 and 172 using line ID26:
*createmark surfaces 1 171 172
*surfacemarkclipwithline 1 26
