Creates a connector from a list and assigns a
connectorcontrol/connectorcontroldefault.
*CE_ConnectorCreateByListWithCC
entity_type list_id ce_style num_links link_entity_type link_mark_id string_array
number_of_strings cc_type cc_name
HyperMesh Tcl Modify Command
Creates a connector from a list and assigns a connectorcontrol/connectorcontroldefault.
- entity_type
- The entity type that specifies the location to create connectors. Valid values
are:
- elems (for area)
- lines (for spot, bolt, seam and area)
- nodes (for spot, bolt and apply_mass)
- points (for spot, bolt and apply_mass)
- surfs (for area).
- list_id
- The ID of the list containing the entities. Valid values are 1 and 2.
- ce_style
- The style of connectors to create. Valid values are apply_mass, area, bolt, seam, and
spot.
- num_links
- The number of links to use.
- link_entity_type
- The type of entity to create links for. Valid values are:
- comps (for spot, bolt, seam, area or apply_mass)
- elems (for spot or apply_mass)
- nodes (for spot or apply_mass)
- surfs (for spot, seam or area)
- tags (for spot or apply_mass)
- link_mark_id
- The ID of the mark of link entities. Valid values are 1 and 2.
- string_array
- The string array ID that contains the additional input parameters. The string array is
created using the *createstringarray command. This should always be
set to 1.
- Strings are indicated using the format "name=value". Valid strings are:
- area_mesh_size=<value>
- The mesh size for area connectors when entity_type is surfs.
Default 10.0.
- area_mesh_type=<value>
- The mesh type for area connectors when entity_type is
surfs.
- 0 - Trias
- 1 - Quads
- 2 - Mixed
- 3 - Right trias
- area_offset=<value>
- Offset area connectors created from node or line lists from the selected
location by this value. Default 0.0.
- area_width=<value>
- Width of area connectors created from node or line lists. Default 1.0.
- line_density=<value>
- The density for spot or seam connectors on lines. Default 0.0.
- line_offset=<value>
- Offset value from the ends of the line for spot or seam connectors on lines.
Default 0.0.
- line_offset_flag=<value>
- 0 - Do not offset connectors (default)
- 1 - Offset connectors
- line_spacing=<value>
- The spacing for spot or seam connectors on lines. Default 1.0.
- link_elems_geom=<value>
- Specifies whether to connect elems (default) or geom.
- link_rule=<value>
- Specifies the link rule. Valid values are now, at_fe_realize or none
(default).
- relink_rule=<value>
- Specifies the relink rule. Valid values are id, name or none (default).
- seam_area_group=<value>
- Flag for seam or area connector grouping:
- 0 - No (default)
- 1 - Yes
- tol=<value>
- Add entities as links only within this distance of the specified location.
Default 0.0.
- tol_flag=<value>
- 0 - Do not use tol (default)
- 1 - Use tol
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using
*createstringarray.
- cc_type
- The type of control to assign. Valid values are connectorcontrol and
- cc_name
- The name of the connectorcontrol/connectorcontroldefault to assign.
Examples
Create a seam connector at the location of line 10 to connect component 3 and 4 using a
tolerance of 6.0 and assign connectorcontrol
seam_quad_ltb:
*createlist lines 1 10
*createmark components 2 3 4
*createstringarray 5 "link_elems_geom=elems" "link_rule=now" "relink_rule=none" "tol_flag=1" "tol=6.000000"
*CE_ConnectorCreateByListWithCC lines 1 "seam" 2 comps 2 1 5 connectorcontrol "seam_quad_ltb"
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
