*pointmodify
Specifies new coordinates for the point.
*pointmodify point_id x y z
HyperMesh Tcl Modify Command
- point_id
- ID of the point to be modified.
- x/y/z
- New point coordinates.
*createpoint 0 0 0 0
*createpoint 10 0 0 0
*window 0 0 0 0 0
*pointmodify 2 5 0 0
*createpointsbetweenpoints 1 2 1
This command is called from the distance panel.
None.
