*metadatamarkintarray
Creates integer array metadata on the specified mark of entities.
*metadatamarkintarray entity_type mark_id name integer_array number_of_integers
HyperMesh Tcl Modify Command
- entity_type
- The type of entities contained on the mark.
- mark_id
- The ID of the mark containing the entities to which the metadata will be added. Valid values are 1 and 2.
- name
- The name by which the metadata will be referenced.
- integer_array
- The ID of the integer array that contains the values. The array is created using the *createarray command. This should always be set to 1.
- number_of_integers
- Integer indicating the size (number of integers) in the array created using *createarray.
*createmark elems 1 1-100
*createarray 2 5 7
*metadatamarkintarray elems 1 "Int_Vals" 1 2Errors
# Handle error
