*nodemarkaddtempmark
Places a node on the temporary node mark.
*nodemarkaddtempmark mark
HyperMesh Tcl Modify Command
- mark
- The ID of the mark that contains the nodes to be placed on the temporary node mark.
To place nodes 100, 101, 102, and 103 on the temporary node mark:
*createmark nodes 1 100 101 102 103
*nodemarkaddtempmark 1
Placing nodes on the temporary mark prevents nodes from being deleted and identifies temporary nodes with a yellow circle.
None.
