*markintersectplane
Selects a chain of elements and nodes cut by a given section plane.
*markintersectplane entity_type EntityMark Plane ElemOutMark NodeOutMark
HyperMesh Tcl Modify Command
- entity_type
- The type of entity on the mark. Valid values are elements and components.
- EntityMark
- The mark containing the elements or components to be intersected.
- Plane
- The ID of the plane to use for intersection calculations.
- ElemOutMark
- The mark to contain the intersected elements
- NodeOutMark
- The mark to contain one row of nodes along the intersected elements.
To find the nodes and elements inside of the components mark cut by a user-defined plane, and place these nodes/elems into mark 2:
*createmark elements 1 displayed
*createplane 1 0.0002 -0.3832 0.0004 850.3620 237.5095 349.0000
*markintersectplane components 1 1 2 2
None.
