*removetempcleanupfile
Use this command to remove temporary files created by the use of *autotopocleanup.
HyperMesh Tcl Modify Command
None required.
This example shows a script that uses the *autotopocleanup() command:
*createmark surfaces 1 "displayed"
*autotopocleanup 1 "nvh10.criteria" "nvh10.param"
None.
