*renumbersolveridall
Renumbers the solver IDs for all entities in the model.
*renumbersolveridall start_id incr_val offset_val offset_flag reserved_1 reserved_2 reserved_3
HyperMesh Tcl Modify Command
This command renumbers the solver IDs for all entities in the model.
This command works in two ways. If the entity has solver IDs, the command will renumber the solver IDs and not the HyperMesh internal IDs. However, if the entity does not have solver IDs, the command will renumber the HyperMesh internal IDs (see *renumberall).
- start_id
- Integer value > 0 specifying the starting value.
- incr_val
- Integer value > 0 specifying the renumbering increment.
- offset_val
- Integer value to use for offsetting. Can be positive or negative as long as after renumbering all entities will have a positive ID.
- offset_flag
- Flag to specify whether to use offsetting.
- reserved_1
- Reserved for future use. Must be set to 0.
- reserved_2
- reserved_3
*renumbersolveridall 100 1 0 0 0 0 0.0Errors
# Handle error
