*titlemodify
Modifies a title entity.
*titlemodify titlename itemname string value plot
HyperMesh Tcl Modify Command
- titlename
- The name of the title.
- itemname
- The name of the item to be modified. itemname can be one of the following options:
- string
- The string value to which the modified item should be set. When itemname is titletext, the title displays a string.
- value
- The value to which the modified item should be set. Used for all itemnames, except titletext.
- plot
- Designates whether the title will be plotted after modification.
*titlemodify "test" "borderon" "" 1 0
*titlemodify "test" "bordercolor" "" 4 0
*titlemodify "test" "titletext" "This is test" 0 1
*titlemodify "test" "titlefont" "" 3 1
*titlemodify "test" "titleanchor" "" 1 1
*titlemodify "test" "borderxmin" "" 0.469273743 0
*titlemodify "test" "borderymin" "" 0.120287253 0
None.
