*sketchintersect
Adds intersected curves into the sketch by intersecting selected entities with the sketch work plane.
*sketchintersect sketch_id entity_type mark_id ?create_entities? ?only_displayed?
HyperMesh Tcl Modify Command
- sketch_id
- The ID of the sketch entity.
- entity_type
- The type of selected entities. Valid values are parts, solids, and surfaces.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- create_entities
- 0 - Intersected curves are added as guide curves in the sketch.
- only_displayed
- 0 - All entities in the input mark are considered.
Examples
*createmark solids 1 all
*sketchintersect 5 solids 1 1 1
# Handle error
Version History
2021.2
