*EntityPreviewUnused
Searches the specified entities for any unused entities, and stores them in the outputmark.
*EntityPreviewUnused entity_type outputmark
HyperMesh Tcl Modify Command
- entity_type
- The entity type to check.
- outputmark
- The unused entities IDs.
*EntityPreviewUnused props mark - Props
- Unused when there are no components, elements, or attributes pointing to the property.
- Mats
- Unused when there are no components, properties, groups, or attributes pointing to the material
- Curves
- Unused when the curve is not contained in any plots or when no attributes point to the curve.
