*min_size_node_movement
Move feature nodes to solve minimum element size failures.
*min_size_node_movement mark_id
HyperMesh Tcl Modify Command
- Move across shared edges
- Move across free edges
- Move across non-manifold edges
- A set of 1D elements along FE edges
- If no 1D element is present in the model, using the feature angle given in the parameter file
- Node - geometry association
Node - geometry association is maintained after feature node are moved, however, free edge nodes may move tangential away from the surface and lose association.
- Internal low curvature shared edges
- Internal high curvature edges
- Free edges
- Non-manifold edges
Node movement is also part of the *rebuild_mesh command.
- mark_id
- The ID of the mark containing the elements to correct. Valid values are 1 and 2.
*createstringarray 14 " 0 penalty value 0.00 0.00 0.50 1.00 5.00" \
" 1 min length 1 2.0 5.000 4.333 3.666 3.000 2.833 2" \
" 2 max length 1 1.5 5.000 6.200 7.320 9.000 11.290 0" \
" 3 aspect ratio 1 1.0 1.000 2.000 4.000 5.000 10.000 0" \
" 4 warpage 1 2.0 0.000 5.000 15.000 20.000 40.000 0" \
" 5 max angle quad 1 1.0 90.000 110.000 140.000 150.000 165.000 0" \
" 6 min angle quad 1 1.0 90.000 70.000 40.000 30.000 15.000 0" \
" 7 max angle tria 1 1.0 60.000 80.000 120.000 130.000 155.000 0" \
" 8 min angle tria 1 1.0 60.000 50.000 30.000 20.000 10.000 0" \
" 9 skew 1 1.5 0.000 10.000 50.000 60.000 75.000 0" \
" 10 jacobian 1 2.0 1.000 0.900 0.600 0.500 0.350 0" \
" 11 chordal dev 0 0.0 0.000 0.300 0.800 1.000 2.000 0" \
" 12 taper 0 1.0 0.000 0.200 0.500 0.600 0.900 0" \
" 13 % of trias 1 2.0 0.000 3.000 4.500 6.000 9.000 0"
*setqualitycriteria 1 14 0
*elementchecksettings -1 0 0 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
*createstringarray 106 "fileversion 20180" "geometry_cleanup_flag 1" \
"meshing_flag 5" "element_size 5.0" \
"element_type 2" "mesh_align 3" \
"element_order 1" "surf_component 1" \
"feature_angle 30.0" "holes_table_begin" "appl_surf(1)" \
"appl_solid(0)" "appl_cordsfiles(0)" "appl_flanged_suppr(1)" "flanged_suppr_height(1.4)" \
"narrow_slots_type(1)" "appl_rmv_washer_loops(1)" "abs_fixed_nodes_count_max(-8)" \
"rad(0.0,2.2) do action(1) washer(0) " "rad(2.2,3.01) do action(0) elems(4) washer(0) " \
"rad(3.01,4.7) do action(0) elems(6) washer(1) layers(3.5) " "rad(4.7,9.0) do action(0) elems(8) washer(1) layers(0.75*radius) " \
"rad(9.0,11.0) do action(0) elems(8) washer(1) layers(7.0) " "rad(11.0,20) do action(0) elems(8) washer(1) layers(auto) " \
"rad(0.0,2.2) solid(1) do action(1) " "rad(2.2,3.01) solid(1) do action(0) elems(4) " \
"rad(3.01,20) solid(1) do action(0) elems(6) " "holes_table_end" "edge_fillet_recognition 1" \
"max_fillet_radius 5.0" "surface_fillet_table_begin" "surface_fillet_recognition(1)" \
"minimize_transitions(1)" "rad(0,2.2) wid(3.0,6.2) do split(suppress_on)" \
"rad(2.2,15) wid(3.4,6.2) do elems(1)" "rad(0,25.0) wid(6.2,9.2) do elems(2)" \
"rad(0,35.0) wid(9.2,12.5) do elems(3)" "rad(0,40.0) wid(12.5,25.0) do chordal_deviation(0.2)" \
"surface_fillet_table_end" "del_dupl_surfs_flag 2" "del_dupl_surfs_tol -1" \
"edges_stitch_flags 0" "max_edges_stitch_tol -1.0" \
"fix_overlapsurfs_flag 1" "overlapsurfs_maxtangangle -1.0" \
"merge_narrow_surfs 1" "narrow_surfs_merge_width Lmin*0.67" \
"beads_suppression 1" "beads_recognition 1" \
"minimal_beads_height 1.4" "beads_treat_flags 1" \
"flange_recognition 1" "flange_elements_across 3" \
"flange_max_width 30.0" "flange_min_width 8.0" \
"flanges_treat_flags 1" "flange_max_remove_width -1.0" \
"appl_tria_reduction 1" "common_mesh_flow 0" \
"extract_thinsolids 1" "midsurf_method 3" \
"thinsolid_ratio 0.3" "max_thickness 10.0" \
"extract_feature_angle 25.0" "pre_midsurf_cleanup 1" \
"direct_midmesh 0" "ignore_flat_edges 1" \
"flatten_connections 0" "defeat_open_width_on 1" \
"defeat_open_width 1.0" "supp_proxim_edges_on 1" \
"supp_proxim_edges 0.9" "combine_nonmanifold_on 1" \
"combine_nonmanifold 0.7" "midmesh_extract_elem_size 2.0" \
"remove_logo 1" "logo_max_size 30.0" \
"logo_max_height 1.4" "logo_min_concavity 1.0" \
"threads_removal 0" "threads_toremove_max_depth 5.0" \
"threads_replacediametertype -2" "folded_elems_angle 150.0" \
"smooth_elems_target 0.2" "fillets_mesh_flow 0" \
"failed_elems_cleanup_flgs 8" "move_nodes_across_feature_edges 1" \
"featureedge_nodes_moveacross_max L*0.1" "move_nodes_across_free_edges 1" \
"freeedge_nodes_moveacross_max L*0.05" "move_nodes_across_t_edges 1" \
"tedge_nodes_moveacross_max L*0.05" "move_normal_flag 1" \
"move_normal_dist 0.8" "divide_warped_quads 1" \
"ignore_comps_boundary 0" "gen_topology_prepare_flags 7" \
"cleanup_comp_flag 0 " "comp_select " \
"use_wildcards_for_compsnames 0" "cleanup_tolerances auto" \
"suppress_features_rate 1" "feat_charsize_method 1" \
"custom_feat_suppr_maxangle 25.0" "uncond_constr_lines_suppress 0" \
"aggressive_fillet_lines_suppress 0"
*createbatchparamsfromstrings 1 106
*createmark elements 1 all
*min_size_node_movement 1
# Handle error
}Version History
2019.1
