*morphupdatemvnodes
Updates nodes on mark to be registered for the morph volumes on mark.
*morphupdatemvnodes ctype cmark ntype nmark
HyperMesh Tcl Modify Command
- ctype
- Hypercubes
- cmark
- Mark number of morph volumes.
- ntype
- Nodes
- nmark
- Mark number of nodes.
*morphupdatemvnodes HYPERCUBES 1 NODES 1
This command updates the nodes on the mark to be registered to the morph volumes on the mark.
If a node is not within any of the morph volumes on the mark or its original morph volume it will still be 'registered' but not affected by any morph volume unless a morph volume is morphed to enclose that node. This can occur when morphing and the morph volumes are "inactive" (see *morphupdateparameter() "mvon"). Switching the morph volumes to being "active" automatically re-registers all nodes.
None.
