*morphremoveconstraint
Remove constraint(s).
*morphremoveconstraint nodetype marknode option
HyperMesh Tcl Modify Command
- nodetype
- Nodes or morphconstraints
- marknode
- Node or morphconstraint mark number.
- option
- 0 - Remove nodes on mark from morph constraints.
*morphremoveconstraint NODES 1 1
If option is 0, any constraints on the nodes on the mark are removed.
None.
