*attributeupdateentityidarrayelementmark
Updates one element of an attribute of type 2D entity ID array.
*attributeupdateentityidarrayelementmark entity_type mark identifier solver status behavior target_entity index value
HyperMesh Tcl Modify Command
- entity_type
- The type of entity that owns the attribute.
- mark
- The number of the mark where the list of IDs resides.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- target_entity
- The type of entity to which the attribute refers.
- index
- Index into the array (first index is zero).
- value
- The new value of the 2D array element.
Examples
Assuming you want to update an element in an entity ID array attribute to point to a loadcol with an ID of 5. The attributes are found on materials with ID's of 7 and 8, do the following:
*createmark materials 1 7 8
*attributeupdateentityidarrayelementmark materials 1 1234 1 2 0 loadcols 0 5
