*maploadtomesh
Creates loads on an FE mesh that correspond to a load on the underlying geometry.
*maploadtomesh markmask
HyperMesh Tcl Modify Command
markmask
ID of the entity.
To create temperature loads on an FE mesh that corresponds to the given geometry load
*createmark loadcols 1 "m"
*maploadtomesh 1
This command is applicable only from HyperMesh 6.0 onwards.
None.
