*surfacecopyedges
Create lines from the edges of a surface.
*surfacecopyedges surface list all_edges
HyperMesh Tcl Modify Command
surface
A surface that contains edges (a full sphere or torus does not contain edges).
list
The mark ID of the nodes used to select the surface edges (if all_edges is 0).
all_edges
1 - Copy all edges of the surface to new lines.
0 - Only copy edges that have a node created on them (from list).
To copy all edges of surface 1 to new lines:
*createlist nodes 2
*surfacecopyedges 1 2 1
*createmark() is required for this command.
None.
