*surfacemarksplitwithlines
Splits a mark of surfaces with lines swept along a vector.
*surfacemarksplitwithlines surf_mark_id line_mark_id vector_id trim_flag distance
HyperMesh Tcl Modify Command
Changes the number of lines used to display an existing surface.
- surf_mark_id
- The mark ID containing the surfaces to split. Valid values are 1 and 2.
- line_mark_id
- The mark ID containing the lines to use for splitting. Valid values are 1 and 2.
- vector_id
- The vector ID to use for the split direction. This is defined using the *createvector command.
- trim_flag
- Bit value defining the trim options (Bit0 + 2*Bit1 + 4*Bit2 + 8*Bit3):
- Bit0
- 0 - Sweep using the distance value
- Bit1
- 0 - Project using vector_id in both directions
- Bit2
- 0 - Project using vector_id if provided and non-zero length
- Bit3
- 0 - Do not create fixed points at line ends
- distance
- The distance to sweep, if trim_flag is 0.
*createmark surfaces 1 15 16
*createmark lines 1 displayed
*createvector 1 0.0000 0.0000 1.0000
*surfacemarksplitwithlines 1 1 1 1 0.5Errors
# Handle error
