*absorbbeamsections
FE-absorb 1D properties into beam sections.
*absorbbeamsections ?<select_type>=<selection>? ?option=<value>? ?tolerance=<value>? ?deleteunused=<value>?
HyperMesh Tcl Modify Command
This command creates/compares beam sections with 1D property values as per the options provided. Currently valid only for OptiStruct and Nastran profiles.
- <select_type>=<selection>
- The properties to be modified. There are several ways to provide the entities to be
modified. Only one option can be used at a time. If not specified, all properties in
the model are considered:
- id=<id>
- The ID of the single entity to modify.
- mark=<mark_id>
- The ID of the mark containing the entities to modify.
- deleteunused=<value>
- 0 - Preserves the beam sections not referenced in any entity.
- option=<value>
- 0 - Create new beam sections if there are not beam sections attached to the 1D properties (default).
- tolerance=<value>
- Valid for option=1 to compare the beam section values and property values with the user defined tolerance value. Default value is 0.01.
Examples
*absorbbeamsections
*absorbbeamsections option=0
*createmark props 1 all
*absorbbeamsections mark=1
*absorbbeamsections mark=1 option=0
*absorbbeamsections id=1 option=1
*absorbbeamsections id=1 tolerance=0.05
*absorbbeamsections id=1 option=2
# Handle error
Version History
2019
