*surfacedisplaynormals
Turns on the display of surface normals.
*surfacedisplaynormals entity_type mark_id size
HyperMesh Tcl Modify Command
The display type is defined by *setsurfacenormalsdisplaytype.
- entity_type
- The type of entity to display normals for. Valid values are surfaces, solids and components.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- size
- Specifies the size of the normal graphics to be drawn, if vector normal display is set. If set to zero, the vector is drawn at 10% of the screen size.
To turn on the display of normals for surfaces 1-10 at 10% screen size:
*createmark surfs 1 1-10
*surfacedisplaynormals surfs 1 0
# Handle error
