*correctoverflowsubmodelentityids
Corrects an entity ID range overflow for a submodel.
*correctoverflowsubmodelentityids submodel_type id entity_type option renum_option ?pool_id?
HyperMesh Tcl Modify Command
This command corrects an entity ID range overflow for a submodel.
- submodel_type
- Submodel type to correct the ID range overflow for. Valid values are:
- includes
- includefiles
- id
- The ID of the submodel.
- entity_type
- The type of entity to correct the overflow for.
- option
- 0 - Overflow IDs
- renum_option
- 1 - Compact and fit (default)
- pool_id
- The optional ID of the solver pool.
Examples
*correctoverflowsubmodelentityids includes 1 comps 2 2
*correctoverflowsubmodelentityids includes 1 0 2 2
# Handle error
Version History
12.0.110
2019 - Added new optional argument pool_id.
