*systemcreate3nodes
Creates a rectangular coordinate system.
*systemcreate3nodes type origin axisname axispt planename planept
HyperMesh Tcl Modify Command
- type
- The type of system being created.
- origin
- The ID of a node which defines the origin.
- axisname
- A string which identifies the axis being defined with the next parameter (x, y, or z).
- axispt
- The ID of a node which defines a point on the axis defined by axisname.
- planename
- A string which identifies the plane being defined with the next parameter (xy, xz, or yz).
- planept
- The ID of a node which defines a point on the plane defined by planename.
*systemcreate3nodes 1 1 x 2 xy 3 Errors
None.
