Deprecated Tcl Modify Commands
The list of deprecated Tcl modify commands, and the new commands to use.
| Deprecated Commands | New Commands to Use |
| *accepteditedsurface | *accepteditedsurface_with_user_tolerance |
| *add_washer_elements | *add_multi_washer_elements |
| *admasconnectivityupdatemultentselect | *admasconnectivityupdatemultentselectwithvisnod |
| *admascreatemultentselect | *admascreatemultentselectwithsets |
| *allowduplicateids | *setoption duplicate_ids |
| *animatelinear | |
| *animatemodal | |
| *animatetransient | |
| *bagcreate | *createentity |
| *bagentityupdate | *setvalue |
| *beadboundsupdate | *setvalue |
| *beadparamsupdate | *setvalue |
| *beamsectioncreatestandard | *beamsectioncreatestandardsolver |
| *bitmapanimationmode | *setoption bitmap_animation_mode |
| *blockcreate | *createentity |
| *blockupdate | *setvalue |
| *cardcreate | *createentity |
| *CE_ExportMasterConnectorsFile | *CE_ExportMainConnectorsFile |
| *CE_FE_AbsorbAndCreate | |
| *centroid1dmode | *setoption 1d_at_centroid |
| *change_distance_between_faces | *setvalue |
| *cleanuptoleranceset | *setoption cleanup_tolerance |
| *clipboundaryelements | *setoption clip_boundary_elements |
| *coarsen_and_decimate_mesh | *coarsen_and_decimate_mesh2 |
| *coincidentnodepickmode | *setoption coincident_picking |
| *coincidentpickmode | *setoption coincident_picking |
| *collectorcreate | *createentity |
| *collectorcreateonly | *createentity |
| *collectorcreatesameas | *createentitysameas |
| *component_changesurflines | *setoption surface_uv_lines |
| *compositeshuffledesvarcreate | *createentity |
| *compositeshuffledesvarcreatewithlaminateoption | *createentity |
| *compositeshuffledesvarupdate | *setvalue |
| *compositeshuffledesvarupdatewithlaminateoption | *setvalue |
| *compositeshufflepairingconstraintupdate | *setvalue |
| *compositesizedesvarcreate | *createentity |
| *compositesizedesvarcreatewithlaminateoption | *createentity |
| *compositesizedesvarupdate | *setvalue |
| *compositesizedesvarupdatewithlaminateoption | *setvalue |
| *compositesizelaminatethicknessupdate | *setvalue |
| *connect_surfaces | *connect_surfaces_11 |
| *connect_surfaces_over_edges | *connect_surfaces_11 |
| *control_sum | *control_sum_print |
| *control_sum_2 | *control_sum_print |
| *control_sum_3 | *control_sum_print |
| *createellipsoid | *createellipsoids |
| *createellipsoidbypoint | *createellipsoidsbypoints |
| *create2dseatbelt | *createentity |
| *create2dseatbeltwithmeshelementsize | *createentity |
| *create_sbelt | *createentity |
| *create_sbelt2D | *createentity |
| *createblockwithsystem | *createentity |
| *createnode | *createentity |
| *createseatbelt | *createentity |
| *createseatbeltline | *createentity |
| *createseatbeltlinewithmesh | *createentity |
| *createseatbeltmesh | *createentity |
| *createseatbeltsurfaceandlines | *createentity |
| *createseatbeltsurfaceandlinesUsingOrientNode | *createentity |
| *createsimpleblock | *createentity |
| *ddvaladdrange | *setvalue |
| *ddvaladdvalues | *setvalue |
| *ddvalcreate | *createentity |
| *deleteelementsmode | *setoption delete_elements_mode |
| *dequationcreate | *createentity |
| *dequationupdate | *setvalue |
| *desvarlinkcreate | *createentity |
| *desvarlinkcreatewithfunction | *createentity |
| *desvarlinkupdate | *setvalue |
| *desvarlinkupdatewithfunction | *setvalue |
| *detailedelements | *setoption detailed_elements |
| *detailedelements_beamvis | *setoption detailed_elements_beamvis |
| *detailedelements_shellvis | *setoption detailed_elements_shellvis |
| *dictionaryload | *createentity/*setvalue |
| *dictionaryreset | *setvalue |
| *dictionaryresetsolver | *setvalue |
| *dictionaryupdatebymark | *setvalue |
| *dictionaryupdateentry | *setvalue |
| *displayimporterrors | *setoption display_import_errors |
| *dvprelcreate | *createentity |
| *dvprelupdate | *setvalue |
| *elementhandle | *setoption element_handle |
| *elementorder | *setoption element_order |
| *elementqualityoptimizeelement | *elementqualityoptimizeelementnew |
| *elementqualityoptimizenode | *elementqualityoptimizenodenew |
| *elementqualityoptimizenode1 | *elementqualityoptimizenodenew |
| *elementqualityplacenode | *elementqualityplacenodenew |
| *elementqualityplacenode1 | *elementqualityplacenodenew |
| *elementqualitysmoothnodes | *elementqualitysmoothnodesnew |
| *elementqualityswapedge | *elementqualityswapedgenew |
| *elementsizeset | *setoption element_size |
| *ellipsoidupdate | *setvalue |
| *entityhighlighting | *setoption entity_highlighting |
| *entitysetaddentities | *setvalue |
| *entitysetcreate | *createentity |
| *entitysetcreatelist | *createentity |
| *entitysetdelentities | *setvalue |
| *entitysetupdate | *setvalue |
| *entitysetupdatelist | *setvalue |
| *entitysuppressactive | *setvalue |
| *entitysuppressoutput | *setvalue |
| *equationhandle | *setoption equation_handle |
| *equationupdate | *setvalue |
| *equationupdateallconstant | *setvalue |
| *equationupdatealldofswts | *setvalue |
| *exponentialdisplay | *setoption exponential_display |
| *fbddisplacement | *freebodysectiondisplacement |
| *fbdforce | *freebodysectionforce |
| *featureangleset | *setoption feature_angle |
| *feinput | *feinputwithdata2 |
| *feinput2 | *feinputwithdata2 |
| *feinputdefault | *feinputwithdata2 |
| *feinputwithdata | *feinputwithdata2 |
| *feoutput | *feoutputwithdata |
| *feoutputtimeinfo | *setoption feoutput_time_info |
| *fieldofview | *setoption perspective_fov |
| *findflangesend/*findflangesinit/*findflangesproximityshell/*findflangestoposhell | hm_flangedetectioninit family of commands |
| *findholesend/*findholesinit/*findholesshell/*findholessolid | hm_holedetectioninit family of commands |
| *findnodesbetweencomponents | *findbetween |
| *fixedpointhandle | *setoption fixed_point_handle |
| *forcetextblack | *setoption force_text_black |
| *formulasetcreate | *createentity |
| *formulasetcreateall | *createentity |
| *formulasetcreatelist | *createentity |
| *formulasetcreaterange | *createentity |
| *formulasetcreaterangewithexcept | *createentity |
| *formulasetdeleteclause | *setvalue |
| *freeshapedesvarcreate | *createentity |
| *freeshapedesvarcreatewithsetoption | *createentity |
| *freeshapedesvarupdate | *setvalue |
| *freeshapedesvarupdatewithsetoption | *setvalue |
| *freeshapedrawextrusionpdate | *setvalue |
| *freeshapegridconstraintsupdate | *setvalue |
| *freeshapegridconstraintsupdatewithsetoption | *setvalue |
| *freeshapeparametersupdate | *setvalue |
| *freeshapeparametersupdatewithlimits | *setvalue |
| *freeshapeparametersupdatewithsmoothing | *setvalue |
| *freeshapeparametersupdatewithtransition | *setvalue |
| *freeshapepatternupdate | *setvalue |
| *freeshapesideconstraintsbarrierupdatebyblocks | *setvalue |
| *freeshapesideconstraintsbarrierupdatemanual | *setvalue |
| *freesizedesvarcreate | *createentity |
| *freesizedesvarcreatewithlaminateoption | *createentity |
| *freesizedesvarcreatewithstackoption | *createentity |
| *freesizedesvarupdate | *setvalue |
| *freesizedesvarupdatewithlaminateoption | *setvalue |
| *freesizedesvarupdatewithstackoption | *setvalue |
| *freesizelaminatethicknessupdate | *setvalue |
| *freesizeparametersupdate | *setvalue |
| *freesizeparametersupdatewithfatigue | *setvalue |
| *freesizepatternupdate | *setvalue |
| *freesizerepetitionupdate | *setvalue |
| *freesizesymmetryupdate | *setvalue |
| *freesizeupdatetapeattribute | *setvalue |
| *freesizezonebasedupdate | *setvalue |
| *gaugedesvarcreate | *createentity |
| *gaugedesvarcreategeneralized | *createentity |
| *gaugedesvarcreatewithddvalfield | *createentity |
| *gaugedesvarupdate | *setvalue |
| *gaugedesvarupdategeneralized | *setvalue |
| *gaugedesvarupdatewithddvalfield | *setvalue |
| *geometrytoleranceset | *setoption cleanup_tolerance |
| *geomfeatureangleset | *setoption geom_feature_angle |
| *geomoutputdata | *geomexport |
| *geomoutputdata2 | *geomexport |
| *geomstitching | *setoption geom_stitching |
| *graphic_label | *setoption load_solver_label |
| *graphicsfileblankbackground | *setoption graphics_file_blank_background |
| *graphicsimplificationmode | *setoption graphics_simplification_component *setoption graphics_simplification_mode |
| *hf_CheckDieModuleElements | |
| *hf_CreateAutomaticTL | |
| *hf_trim | *hf_trim_multi |
| *hm_autocleanup | *autotopocleanup |
| *hm_auto_elem_cleanup | *hm_auto_elem_cleanup_new |
| *hyperbeambatch | |
| *iges_write | *geomexport |
| *iges_write_units | *geomexport |
| *importacis | *geomimport |
| *importdes | *geomimport |
| *importdxf | *geomimport |
| *importinca | *geomimport |
| *importparasolid | *geomimport |
| *importpdgs | *geomimport |
| *interfaceall | *setvalue |
| *interfacebox | *setvalue |
| *interfacecomponent | *setvalue |
| *interfacecreate | *createentity |
| *interfacecreatewithid | *createentity |
| *interfacecontactsurf | *setvalue |
| *interfacedefinition | *setvalue |
| *interfacesets | *setvalue |
| *jointelement_update | *setvalue |
| *laminatecreate | *createentity |
| *laminateupdate | *setvalue |
| *latparmcreate | *createentity |
| *latparmupdate | *setvalue |
| *latparmupdatebucksfparameter | *setvalue |
| *latparmupdatemaxradparameter | *setvalue |
| *linefromsurfedge | *linefromsurfedgecomp |
| *linehandle | *setoption line_handle |
| *linemarkcombine | *linecombine |
| *linemesh_preparedata | *linemesh_preparedata1 |
| *linemesh_preparenodeslist | *linemesh_preparenodeslist1 |
| *linemesh_savedata | *linemesh_savedata1 |
| *linemesh_savedata_bar | *linemesh_savedata_bar1 |
| *loadhandle | *setoption load_handle |
| *loadlabel | *setoption load_label |
| *loadlabelsetcolor | *setoption load_label_color |
| *loadsize | *setoption load_size_magnitude *setoption load_size_type *setoption load_size_uniform |
| *loadstepscreate | *createentity |
| *loadstepscreatesameas | *createentitysameas |
| *loadstepsupdate | *setvalue |
| *loadstepsupdateattributesfromidlist | *setvalue |
| *loadvisualvector | *setoption load_visual_vector |
| *marksuppressactive | *setvalue |
| *marksuppressoutput | *setvalue |
| *maskmark | *maskentitymark |
| *masselementupdate | *setvalue |
| *materialupdate | *setvalue |
| *mbjointupdate | *setvalue |
| *meshdragelements | *meshdragelements2 |
| *meshspinelements | *meshspinelements2 |
| *midsurface_accept_edge_target | *midsurface_accept_edge_target_by_number |
| *midsurface_extract_new | *midsurface_extract_10 |
| *midsurface_offset_by_targets | *midsurface_offset_by_targets_11 |
| *midsurface_remove_edge_target | *midsurface_remove_edge_target_by_number |
| *mixedpropertywarning | *setoption mixed_property_warning |
| *morphaddconstraint | *morphconstraintcreatefc |
| *morphaddconstraintline | *morphconstraintcreateline |
| *morphaddconstraintplane | *morphconstraintcreateplane |
| *morphaddconstraintsurface | *morphconstraintcreatesurf |
| *morphaddconstraintvector | *morphconstraintcreatevec |
| *morphalterangle | *morphalteranglevec |
| *morphaltercurvature | *morphaltercurvectr |
| *morphalterdistance | *morphalterdistancevec |
| *morphalterradius | *morphaltercurvectr |
| *morphcreate | *morphcreatedomaindc |
| *morphcreatedomain | *morphcreatedomaindc |
| *morphcreatedomainglobal | *morphcreatedomainglobalnodes |
| *morphmanualapply | *morphmanualapplyenvelope |
| *morphmapedgestoequation | *morphmapedgestoequationoffset |
| *morphmapedgestoline | *morphmapedgestolineoffset |
| *morphmapedgestonodes | *morphmapedgestonodelistoffset |
| *morphmapedgestonodesoffset | *morphmapedgestonodelistoffset |
| *morphmapedgestoplane | *morphmapedgestoplaneoffset |
| *morphmapedgestosurface | *morphmapedgestosurfaceoffset |
| *morphmapedgestotacit | *morphmapedgestotacitoffset |
| *morphmaptoequation | *morphmaptoequationvecoffset |
| *morphmaptoequationvec | *morphmaptoequationvecoffset |
| *morphmaptoline | *morphmaptolinevecoffset |
| *morphmaptolinenodes | *morphmaptolinenodesoffset |
| *morphmaptolineoffset | *morphmaptolinenodesoffset |
| *morphmaptolinevec | *morphmaptolinevecoffset |
| *morphmaptonodesnodes | *morphmaptonodesnodelistoffset |
| *morphmaptonodesnodesoffset | *morphmaptonodesnodelistoffset |
| *morphmaptonodesvec | *morphmaptonodelistvecoffset |
| *morphmaptonodesvecoffset | *morphmaptonodelistvecoffset |
| *morphmaptoplane | *morphmaptoplanevecoffset |
| *morphmaptoplanevec | *morphmaptoplanevecoffset |
| *morphmaptosurface | *morphmaptosurfacevecoffset |
| *morphmaptosurfacevec | *morphmaptosurfacevecoffset |
| *morphmaptotacitvec | *morphmaptotacitvecoffset |
| *morphnodesequa | *morphnodesequaoffset |
| *morphnodesequaenvelope | *morphnodesequaoffset |
| *morphnodesline | *morphnodeslineoffset |
| *morphnodeslineenvelope | *morphnodeslineoffset |
| *morphnodesmesh | *morphnodesmeshoffset |
| *morphnodesmeshenvelope | *morphnodesmeshoffset |
| *morphnodesnodes | *morphnodesnodesoffset |
| *morphnodesnodesenvelope | *morphnodesnodesoffset |
| *morphnodesnormal | *morphnodesnormalenvelope |
| *morphnodesplane | *morphnodesplaneoffset |
| *morphnodesplaneenvelope | *morphnodesplaneoffset |
| *morphnodesrotate | *morphnodesrotateenvelope |
| *morphnodesshape | *morphnodesshapeenvelope |
| *morphnodessurf | *morphnodessurfoffset |
| *morphnodessurfenvelope | *morphnodessurfoffset |
| *morphnodestranslate | *morphnodestranslateenvelope |
| *morphnodesvector | *morphnodesvectoroffset |
| *morphnodesvectorenvelope | *morphnodesvectoroffset |
| *morphorganizedomainedge | *morphcombineedges |
| *morphpositionshape | *morphpositionshapemark |
| *morphreflectshape | *morphreflectshapemark |
| *morphremesh | *morphremeshedges |
| *morphsculptmesh | *morphsculptmesh3 |
| *morphsculptmesh2 | *morphsculptmesh3 |
| *morphsculptmeshfea | *morphsculptmesh3 |
| *morphshapecreate | *morphshapecreatecolor |
| *morphsymmetrycreate | *morphsymmetrycreateaxis |
| *morphsymmetryupdatebys | *morphsymmetryupdateaxis |
| *morphtranslateshape | *morphtranslateshapemark |
| *morphupdategraphics | *morphupdateparameter |
| *morphupdateparameter domainicons | *setoption domain_handle |
| *multibody_cogupdate | *setvalue |
| *multibody_sysupdate | *setvalue |
| *multibodycreate | *createentity |
| *multibodycreate_body | *createentity |
| *multibodycreate_duplicate | *createentitysameas |
| *multibodycreate_use | *createentity |
| *nodesassociatetosolid | *nodesassociatetogeometry |
| *nodesassociatetosurface | *nodesassociatetogeometry |
| *normalsadjust | *normalsadjust2 |
| *opticonstraintcreate | *createentity |
| *opticonstraintupdate | *setvalue |
| *opticontrolcreate | *createentity |
| *opticontrolcreate80 | *createentity |
| *opticontrolcreate80sr1 | *createentity |
| *opticontrolupdate | *setvalue |
| *opticontrolupdate80 | *setvalue |
| *opticontrolupdate80sr1 | *setvalue |
| *opticontrolupdateapproxparameters | *setvalue |
| *opticontrolupdatebarconparameters | *setvalue |
| *opticontrolupdatecontolparameters | *setvalue |
| *opticontrolupdateeslparameters | *setvalue |
| *opticontrolupdatemanthrparameters | *setvalue |
| *opticontrolupdateoptimizationparameters | *setvalue |
| *opticontrolupdateremeshparameters | *setvalue |
| *opticontrolupdatetopdiscparameters | *setvalue |
| *opticontrolupdatetopdvparameters | *setvalue |
| *opticontrolupdatetoprstparameters | *setvalue |
| *optictrlcreate | *createentity |
| *optictrlupdate | *setvalue |
| *optidobjrefcreate | *createentity |
| *optidobjrefupdate | *setvalue |
| *optidscreencreate | *createentity |
| *optidscreencreateextended | *createentity |
| *optidscreenupdate | *setvalue |
| *optidscreenupdateextended | *setvalue |
| *optiminmaxcreate | *createentity |
| *optiminmaxupdate | *setvalue |
| *optimized_elements_remesh | *optimized_elements_remesh2 |
| *optiobjectivecreate | *createentity |
| *optiobjectiveupdate | *setvalue |
| *optiresponsecreate | *createentity |
| *optiresponseexcludeelements | *setvalue |
| *optiresponsesetequationdata1 | *setvalue |
| *optiresponsesetequationdata2 | *setvalue |
| *optiresponsesetequationdata3 | *setvalue |
| *optiresponsesetequationdata4 | *setvalue |
| *optiresponseupdate | *setvalue |
| *optiresponseupdatenodeid | *setvalue |
| *optiresponseupdatenormalacceleration | *setvalue |
| *optiresponseupdatenormaldisplacement | *setvalue |
| *optiresponseupdatenormalvelocity | *setvalue |
| *optiresponseupdaterandpsid | *setvalue |
| *optiresponseupdatesubcasetrackingvalue | *setvalue |
| *optitableentrycreate | *tablecreate and *tableaddrow |
| *optitableentryupdate | *tableupdaterow |
| *ossmooth | *ossmooth2 |
| *ossmooth_post | *ossmooth2 |
| *outputblockscreate | *createentity |
| *outputblocksupdate | *setvalue |
| *perspectiveview | *setoption perspective_view |
| *picktoleranceset | *setoption pick_tolerance |
| *plycreate | *createentity |
| *plythicknessfactor | *setoption ply_thickness_factor |
| *plyrealization | *plyrealization_option |
| *plyupdate | *setvalue |
| *propertyupdate | *setvalue |
| *propertyupdateentity | *setvalue |
| *rbe3update | *setvalue |
| *rbe3updatealldofs | *setvalue |
| *rbe3updateallwts | *setvalue |
| *rbe3updatedofs | *setvalue |
| *rbe3updatewts | *setvalue |
| *ReassignSeatbeltRodNodes | *setvalue |
| *rejectbatchmesh | *rejectmark |
| *remesh_master_slave_boolean | *remesh_main_secondary_boolean |
| *renumberinternaltosolverid | |
| *reset_qa_calculator | *setqualitycriteria |
| *reset_qa_calculator_from_file | *readqualitycriteria |
| *restoreview | *restoreviewmask |
| *resultcolortypemode | *setoption contour_type |
| *retainloads | *setoption retain_loads |
| *rigidlinkupdate | *setvalue |
| *rigidsupdate | *setvalue |
| *rigidsupdate_setattach | *setvalue |
| *rigidsupdateconnectivity | *setvalue |
| *rigidwall_motion_update | *setvalue |
| *rodupdate | *setvalue |
| *rotationangleset | *setoption rotation_angle_set |
| *rotationcentermode | *setoption rotation_center_mode |
| *rotationcenteroffscreen | *setoption rotation_center_off_screen |
| *saveview | *saveviewmask |
| *seatbeltnodecreate | *createentity |
| *secondorderfix | *secondorderfix2 |
| *separate_holes_in_3d_body | *separate_holes_in_3d_body_new |
| *setautomeshcolormode | *setoption auto_mesh_color_mode |
| *setbackgroundcolor | *setoption background_colors |
| *setbackgroundcolors | *setoption background_colors |
| *setchordaledgeparams | *set_meshedgeparams |
| *setdisplaycolor | *setoption display_color |
| *setedgemeshparams | *set_meshedgeparams |
| *setelementcolormode | *setoption element_color_mode |
| *setelementinternaledgesmode | *setoption element_internal_edges_mode |
| *setfacemeshparams | *set_meshfaceparams |
| *setgeomrefinelevel | *setoption geom_refine_level |
| *setgeomtopologydisplay | *setoption topology_display_mode |
| *setgraphicsengine | |
| *setlodthreshold | *setoption lod_threshold |
| *sethvlaunchflag | *setoption hv_launch_flag |
| *setmeshlodthreshold | *setoption mesh_lod_threshold |
| *setmeshlinecolor | *setoption mesh_line_color |
| *setmeshtransparency | *setoption mesh_transparency |
| *setparameter | *setvalue |
| *setparametermark | *setvalue |
| *setperformancenormalmode | *setoption performance_normal |
| *setscaleoption | *setoption scale_color *setoption scale_height *setoption scale_position *setoption scale_width |
| *setspecularity | *setoption lighting_mode=0, and specular_intensity |
| *settopologydisplay | *setoption topology_display_mode |
| *settopologydisplayall | *setoption topology_display_mode |
| *settopologydisplaymode | *setoption topology_display_mode |
| *settopologysoliddisplay | *setoption solid_transparency *setoption topology_solid_display_mode |
| *settransparentwithmeshlines | *setoption transparent_with_mesh_lines |
| *shapeboundsupdate | *setvalue |
| *shapeboundsupdatewithddvalfield | *setvalue |
| *shapedesvarcreate | *createentity |
| *shapedesvarsupdate | *setvalue |
| *shapevarcreate | *createentity |
| *shapevarcreate_twonode | *createentity |
| *shapevarupdate | *setvalue |
| *shapevarupdate_twonode | *setvalue |
| *show_new_edge_target | *show_new_edge_target_by_number |
| *showcompositelayers | *setoption show_composite_layers |
| *showgeomlinedir | *setoption show_line_dir |
| *showglobalaxes | *setoption show_global_axes |
| *showscale | *setoption show_scale |
| *shpdesvarcreate | *createentity |
| *shpdesvarcreatewithddvalfield | *setvalue |
| *shpdesvarupdate | *createentity |
| *shpdesvarupdatewithddvalfield | *setvalue |
| *shrink | *setoption shrink_factor *setoption shrink_mode |
| *simulationset | *inputsimulation |
| *sizedesvarcreate | *createentity |
| *sizedesvarcreatewithddvalfield | *createentity |
| *sizedesvarupdate | *setvalue |
| *sizedesvarupdatewithddvalfield | *setvalue |
| *solid_spin_from_surfs | *solidcreatespinsurfwithoffsetangle |
| *sphgenerate | *sphgenerate_new |
| *spinlinetoformsurface | *surfacecreatespinlinewithoffsetangle |
| *spinnodestoformsurface | *surfacecreatespinnodeswithoffsetangle |
| *stereodisplay | *setoption stereo_display |
| *storeAMelemstodatabase | *storemeshtodatabase |
| *surface_chordalmesh | *defaultremeshsurf |
| *surfacefiller | *surfacesplinefillholes and *surfacesplineonlinesloop |
| *surfacemarkchangesurfacelines | *setoption surface_uv_lines |
| *surfacemarkcombine | *selfstitchcombine |
| *surfacereversenormals | *surfacereversenormals2 |
| *surfacesextendintersect | *connect_surfaces_11 |
| *surfacesplineonnodesloop | *surfacesplineonnodesloop2 |
| *surfaceuvlines | *setoption surface_uv_lines |
| *surfisolinecreate | *linecreateatsurfparams |
| *surfmarkoffsetplusminus | *offset_surfaces_and_modify |
| *swapcontactmasterslave | *swapcontactmainsecondary |
| *systemconvertnodetoaxis | *setvalue (see data name definitioncode) |
| *systemcreate | *system |
| *systemdeleteunused | *EntityPreviewUnused and *deletemark |
| *systempreviewunused | *EntityPreviewUnused |
| *systemsetanalysis | *setvalue |
| *systemsetreference | *setvalue |
| *systemsize | *setoption system_size |
| *tagcreate | *createentity |
| *tagcreatelabelbyid | *createentity |
| *tagdisplay | *setoption tag_display |
| *tagtextdisplaymode | *setoption tag_text_display_mode |
| *tagupdate | *setvalue |
| *tagupdatedescription | *setvalue |
| *tagupdateentity | *setvalue |
| *tetra_cfdmesh | *tetmesh |
| *tetra_cfdmesh_transition | *tetmesh |
| *tetra_remesh | *tetmesh |
| *tetra_remesh_transition | *tetmesh |
| *tetra_volumemesh | *tetmesh |
| *tetra_volumemesh_transition | *tetmesh |
| *tetramesh | *tetmesh |
| *tetramesh_transition | *tetmesh |
| *thick1dlines | *setoption thick_1d_lines |
| *thickmeshlines | *setoption thick_mesh_lines |
| *toleranceset | *setoption node_tolerance |
| *topographyboundsupdate | *setvalue |
| *topographydesvarcreate | *createentity |
| *topographydesvarupdate | *setvalue |
| *topographypatternupdate | *setvalue |
| *topographypatternvaluesupdate | *setvalue |
| *topographyrepetitionupdate | *setvalue |
| *topologydesvarcreate | *createentity |
| *topologydesvarupdate | *setvalue |
| *topologydrawupdate | *setvalue |
| *topologydrawupdatewithnoholeandstamp | *setvalue |
| *topologyextrusionupdate | *setvalue |
| *topologylatticeupdate | *setvalue |
| *topologyparametersupdate | *setvalue |
| *topologyparametersupdate80 | *setvalue |
| *topologyparametersupdatewithfatigue | *setvalue |
| *topologyparametersupdatewithmingap | *setvalue |
| *topologyparamsupdate | *setvalue |
| *topologypatternupdate | *setvalue |
| *topologyrepetitionupdate | *setvalue |
| *topologysymmetryupdate | *setvalue |
| *trim_elements | *trim_elements2 |
| *trim_elems_by_circular_hole | *trim_elems_by_multi_circular_hole |
| *unmaskmark | *unmaskentitymark |
| *unmaskmarkedelements | *unmaskentitymark |
| *unsetparameter | *setvalue |
| *unsetparametermark | *setvalue |
| *updateblock | *setvalue |
| *updateblocks | *setvalue |
| *updateblockwithsystem | *setvalue |
| *updatecolor | |
| *updateincludedata | *updateincludedata2 |
| *updateseatbelt | *setvalue |
| *updatesimpleblock | *setvalue |
| *vectorautoscale | *setoption vector_auto_scale |
| *vectorcreate | *createentity |
| *vectorcreate_twonode | *createentity |
| *vectordrawoptions | *setoption vector_size_magnitude *setoption vector_size_type *setoption vector_size_uniform |
| *vectorhandle | *setoption vector_handle |
| *vectorlabel | *setoption vector_label |
| *vectorupdate | *setvalue |
| *vectorupdate_twonode | *setvalue |
| *writeh3d | *writeh3dwithoptions |
| *writeh3dtofile | *writeh3dwithoptions |
| *writeh3dwithorienttofile | *writeh3dwithoptions |
| *writeh3dwithtitlestofile | *writeh3dwithoptions |
| *writequalitycriteria | *writecurrentqualitycriteria |
| *zoomfactorset | *setoption zoom_factor |
