*linestoelementsaddelemsfixed
Marks the specified lines as feature edges before using the command for remeshing elements.
*linestoelementsaddelemsfixed mark_id elem_size
HyperMesh Tcl Modify Command
This command generates plot elements along selected lines with a given density. These plot elements are then used as feature edges for element remeshing. Use of this command implies that it will be followed by a command that performs meshing/remeshing of elements.
mark_id
The ID of the mark containing lines that should be considered to form feature edges in subsequent element remesh operations. Valid values are 1 and 2.
elem_size
The default element edge size used to calculate element densities along the constructed feature edges.
To remesh the displayed elements and create feature edges with element size 10.0 along lines with IDs 1600 and 1601:
*createmark elems 1 displayed
*setusefeatures 1
*createmark lines 2 1600 1601
*linestoelementsaddelemsfixed 2 10
*defaultremeshelems 1 3.0 2 2 0 1 1 1 0 0 0 0 0 30
   # Handle error
Version History
10.0
