*morphalterdistancevec
Alter the distance between two nodes using morphing and measuring along a vector.
*morphalterdistancevec h1type h1mark h2type h2mark n1 n2 hold dist sym con vec
HyperMesh Tcl Modify Command
- h1type
- Handles
- h1mark
- Handle mark number - end a
- h2type
- Handles
- h2mark
- Handle mark number - end b
- n1
- ID of node - end a
- n2
- ID of node - end b
- hold
- Specify which part of the 2-node system to anchor:
- dist
- New distance between n1 and n2
- sym
- Flag for use of symmetry:
- con
- Flag for use of constraints:
- vec
- Vector mark number
*morphalterdistancevec HANDLES 0 HANDLES 1 132 783 0 100.0 1 1 1
The handles on the marks will be moved based on hold to create the new distance dist between n1 and n2 as measured along vector vec. If symmetry is used, all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
None.
