*attributeupdateentityidarraymark
Updates an attribute, which is an array of entity IDs, on a set of entities.
*attributeupdateentityidarraymark entity_type mark identifier solver status behavior targetentity data length
HyperMesh Tcl Modify Command
- entity_type
- The type of entity that owns the attribute.
- mark
- The number of the mark where the list of IDs resides.
- identifier
- The identifier of the attribute.
- solver
- The solver number of the attribute.
- status
- The status of the attribute.
- behavior
- The behavior of the attribute.
- targetentity
- The type of entity to which the attribute refers.
- data
- An array of IDs to entities.
- length
- The length of the data array.
Examples
*createarray 4 0 0 0 0
*attributeupdateentityidarraymark loadcols 1 6436 1 2 0 materials 1 4
