*CE_CreateNodeOnSeamConnector
Creates a node on a seam connector at a given position.
*CE_CreateNodeOnSeamConnector mark_id x y z
HyperMesh Tcl Modify Command
Creates a node on a seam connector at a given position. This node can then be used to trim the seam connector at that location. To create a node with a mouse click on a connector, the x, y, and z values should all be passed as -1.
- mark_id
- The ID of the mark of seam connectors to trim. Valid values are 1 and 2.
- x
- The x position on the seam connector.
- y
- The y position on the seam connector.
- z
- The z position on the seam connector.
Examples
*createmark connectors 1 101
*CE_CreateNodeOnSeamConnector 1 100 50 50
*CE_CreateNodeOnSeamConnector 1 -1 -1 -1
# Handle error
Version History
2021
