*morphorganizedomainsplit
Splits edge domain at given node.
*morphorganizedomainsplit node domain
HyperMesh Tcl Modify Command
node
ID of node.
domain
ID of domain.
*morphorganizedomainsplit 12 32
This command splits the given edge domain into two edge domains at the given node.
   # Handle error
