Transforms a selection of entities using a transformation matrix.
*transformmark
entity_type mark_id r1c1 r1c2 r1c3 r1c4 r2c1 r2c2 r2c3 r2c4 r3c1 r3c2 r3c3 r3c4
r4c1 r4c2 r4c3 r4c4
HyperMesh Tcl Modify Command
This command translates a selection of entities along a vector.
- entity_type
- The type of entity to transform.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- r1c1-r4c4
- The 4x4 transformation matrix, in row-column order. This matrix defines the
reflection, rotation, scaling and translation applied to the entities.
- The scaling is in r1c1(x), r2c2(y), and r3r3(z).
- The translation is in r4c1 (x), r4c2 (y), and r4c3 (z).
- The rotation is in the upper 3x3 matrix.
- The last column is for reflection.
- The steps to use to calculate the matrix are as follows:
- Calculate the angle in radians.
- Construct a matrix to translate from the rotation point to (0,0,0).
- Construct a second matrix to handle the actual rotation.
- Multiply matrix(step2) X matrix(step3).
- Construct a third matrix to translate back to the rotation point.
- Multiply matrix(step4) X matrix(step5).
To rotate all displayed nodes 30 degrees about the x-axis through the point
(0,0,0):
*createmark nodes 1 displayed
*transformmark nodes 1 1 0 0 0 0 0.86603 0.5 0 0 -0.5 0.86603 0 0 0 0 1
To rotate all elements 30 degrees about the x-axis through the point (5,10,6):
*createmark elems 1 all
*transformmark elems 1 1 0 0 0 0 0.86603 0.5 0 0 -0.5 0.86603 0 0 4.3397 -4.1962 1
Incorrect usage results in a
Tcl error. To detect
errors, you can use the
catch
command:
# Handle error
