*morphhypermorphnormal
Create shapes in the normal direction for handles on mark.
*morphhypermorphnormal entity_type1 mark_id_hand entity_type2 mark_id_elem sym con mag
HyperMesh Tcl Modify Command
entity_type1
Valid value is handles.
mark_id_hand
The ID of the mark containing the handles. Valid values are 1 and 2.
entity_type2
Valid value is elements.
mark_id_elem
The ID of the mark containing the elements. Valid values are 1 and 2.
sym
0 - Do not use symmetry
1 - Use symmetry
con
0 - Do not use constraints
1 - Use constraints
mag
Magnitude of perturbation
*morphhypermorphnormal handles 1 elems 1 1 1 5.0
A shape is created for each handle on the mark in the direction of the normal for the handle node at the given magnitude. If symmetry is used, all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.
None.
