*removecrbrelation
Removes a main-secondary relationship for LS-DYNA *CONSTRAINED_RIGID_BODIES keyword.
*removecrbrelation mark_id
HyperMesh Tcl Modify Command
If a main component is removed, then the constrainedrigidbodies entity is deleted. If all secondary components are removed, the constrainedrigidbodies entity is deleted.
- mark_id
- The ID of the mark containing the components.
To remove secondary rigid component 200:
*createmark comps 1 200
*removecrbrelation 1
# Handle error
}Version History
14.0.120
