*setoption - CAD Reader
Sets various CAD reader option values.
*setoption cad_reader=<value> <option>=<value>
HyperMesh Tcl Modify Command
- cad_reader=<value>
- The format of the CAD reader. Valid formats are acis, aveva, catia, catiav6, creo, dxf, iges, inspire, Intergraph, inventor, jt, nx_ct, nx_native, ocx, parasolid, pdgs, rhino, solidworks, step, and vdafs.
- <option>=<value>
- The name of the option and the corresponding value to assign. Valid options for each format can be referred from the “cadiooptionname” attributes of the respective <format>.xml files in <altair_home>/hm/scripts/ImportExport/xml/geometry/import.
Examples
*setoption cad_reader=acis CreationType=Parts
*setoption cad_reader=acis TargetUnits={MKS (m kg N s)}
# Handle error
Version History
2022.1
